DSP metering - Head or Tail?
A quick question, (which i’m sure the answer to which is somewhere in the docs)…
If I want to get the final output volume levels of a channel, do I setMeteringEnabled on the Head or Tail of the DSP chain?
Thanks in advance,
MM
OK. So it looks like CHANNELCONTROL_DSP_INDEX.HEAD gives you the output end of the DSP chain, and CHANNELCONTROL_DSP_INDEX.TAIL gives you the input end.
For example:
Tail = the sound source (e.g a .wav file)
Head = values sent out to the speakers.
So in my case, where I’m upmixing a mono sound to 7.1, I have 3 DSP’s with indices 0, 1 and 2
DSP 0: 8 input channels, 8 output channels = HEAD
DSP 1: 1 input channel, 8 output channels
DSP 2: 1 input channel, 1 output channel = TAIL
MM
