FMOD_DSP_METERING_INFO from a DSP on a 3D SoundChannel
I’m reading the metering info from a DSP attached to a 3D positioned Channel, and the RMS is being affected by the 3D attenuation/panning. I’ve set the DSP index to 1 (and other >0 values), and this does not change that fact.
Based on this documentation, https://www.fmod.org/documentation/#content/generated/overview/dsptutorial.html, I’m led to believe that 3D attenuation/panning for the Channel happens in the “Channel Fader” step. Is this true?
And in general, how would I get the metered info of the signal directly from the wavetable unit stage?
To meter the wavetable I would use
FMOD::DSP* tail;
getDSP(FMOD_CHANNELCONTROL_DSP_TAIL, &tail);
and then use the input metering. A default channel will only have one DSP, so the Channel Fader is the head and tail. You’ll need the input metering to avoid the panning and attenuation affecting the signal.
