Error AndroidJavaException: java.lang.UnsatisfiedLinkError: dlopen failed: library "libfmodL.so" not found on quest build
Audio works perfectly fine in editor, but no sound is playing at all in Quest 2 build. When I profiled it, I got the error " AndroidJavaException: java.lang.UnsatisfiedLinkError: dlopen failed: library “libfmodL.so” not found". I then checked, and the libfmodL.so file IS INCLUDED in the packaged afk. Is this a known issue?
What version of the FMOD integration are you using?
Could I please get a screenshot of your FMOD integration settings:
Also please enable API Error Logging:
And upload the full log when trying to launch the project.
Using FMOD 2.02.22 and unity 2023.3.0b8.
Here is my settings:
I added the logger, but I don’t know where to find the file? Also here is my .so file settings.
Thank you for the images.
Unfortunately, I am unable to reproduce the issue.
Would it be possible to get a copy of your project or a stripped-down version displaying the issue uploaded to your profile? Please note you must register a project with us before uploading files.
Yes of course, I will update you when that is updated my project is currently pending registration.
You have been registered and are good to upload
