Compiling an application using recent Emscripten and FMOD 2.02.15 upstream/w32/fmod_wasm.a with the --closure=1 option to optimize JavaScript I get a lot of errors that seem to originate from FMOD’s JavaScript code:
building:ERROR: Closure compiler run failed:
building:ERROR: Application.js:1001:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable contextForCheck is undeclared
1001| contextForCheck = new (window.AudioContext || window.webkitAudioContext)();
Application.js:1005:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable retValue is undeclared
1005| retValue = 0;
Application.js:1016:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable infocontext is undeclared
1016| infocontext = new (window.AudioContext || window.webkitAudioContext)();
Application.js:1020:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable inforate is undeclared
1020| inforate = infocontext.sampleRate;
Application.js:1026:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mInputRegistered is undeclared
1026| mInputRegistered = false;
Application.js:1029:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable context is undeclared
1029| context = new (window.AudioContext || window.webkitAudioContext)();
Application.js:1033:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable FMOD_JS_MixFunction is undeclared
1033| FMOD_JS_MixFunction = Module.cwrap("FMOD_JS_MixFunction", "void", [ "number" ]);
Application.js:1037:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable _as_script_node is undeclared
1037| _as_script_node = context.createScriptProcessor($1, 0, $0);
Application.js:1040:38: ERROR - [JSC_UNDEFINED_VARIABLE] variable OutputWebAudio_resumeAudio is undeclared
1040| window.addEventListener("touchend", OutputWebAudio_resumeAudio, false);
Application.js:1054:3: ERROR - [JSC_UNDEFINED_VARIABLE] variable _as_output_buffer is undeclared
1054| _as_output_buffer = audioProcessingEvent.outputBuffer;
Application.js:1087:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mWorkletNode is undeclared
1087| mWorkletNode = null;
Application.js:1088:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mModulePolling is undeclared
1088| mModulePolling = false;
Application.js:1089:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mModuleLoading is undeclared
1089| mModuleLoading = false;
Application.js:1090:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mStartInterval is undeclared
1090| mStartInterval = null;
Application.js:1091:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mStopInterval is undeclared
1091| mStopInterval = null;
Application.js:1092:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mSuspendInterval is undeclared
1092| mSuspendInterval = null;
Application.js:1093:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mResumeInterval is undeclared
1093| mResumeInterval = null;
Application.js:1094:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mWorkletNodeConnected is undeclared
1094| mWorkletNodeConnected = false;
Application.js:1096:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mContext is undeclared
1096| mContext = new (window.AudioContext || window.webkitAudioContext)();
Application.js:1106:3: ERROR - [JSC_UNDEFINED_VARIABLE] variable mAddModuleRef is undeclared
1106| mAddModuleRef = 0;
Application.js:1114:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable FMOD_JS_MixerSlowpathFunction is undeclared
1114| FMOD_JS_MixerSlowpathFunction = Module.cwrap("FMOD_JS_MixerSlowpathFunction", "void", []);
Application.js:1115:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable FMOD_JS_MixerFastpathFunction is undeclared
1115| FMOD_JS_MixerFastpathFunction = Module.cwrap("FMOD_JS_MixerFastpathFunction", "void", [ "number" ]);
Application.js:1119:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mSpeakerChannelCount is undeclared
1119| mSpeakerChannelCount = $0;
Application.js:1121:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mUrl is undeclared
1121| mUrl = null;
Application.js:1122:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mOutputData is undeclared
1122| mOutputData = null;
Application.js:1123:2: ERROR - [JSC_UNDEFINED_VARIABLE] variable mSharedArrayBuffers is undeclared
1123| mSharedArrayBuffers = false;
Application.js:1146:38: ERROR - [JSC_UNDEFINED_VARIABLE] variable OutputAudioWorklet_resumeAudio is undeclared
1146| window.addEventListener("touchend", OutputAudioWorklet_resumeAudio, false);
Application.js:1180:19: ERROR - [JSC_UNDEFINED_VARIABLE] variable waitForAudioWorklet is undeclared
1180| mStartInterval = waitForAudioWorklet(function() {
28 error(s), 0 warning(s)
I think these errors stem from missing var keywords. As this code is integrated into the .a library file I can’t change it. Can this be fixed?
