Studio contains event A (play sound) event B (global stop command → stop all A sounds). If we trigger events B and A in the same frame, we are left with silence. Fmod logs are inconclusive about this…
Flow:
- Game log: both start requests and the stop request were sent.
- FMOD log: stream loading occurred.
- FMOD log: no direct instance-state result.
Is this intended behavior? If I inject flushCommands in between, it works as expected.
Yes that is the expected behavior. As FMOD Studio works in asynchronously (FMOD Engine | Studio Api Threads - Studio Thread Overview) the events are created at the same time, then they are updated at the same time. As the Stop command is for all existing instances of event A it is stopped.
Adding the FlushCommand()(FMOD Engine | Studio Api System - Studio::System::Flushcommands) will force the Stop command to happen before event A is created so it is allowed to play out:
Without FlushCommand()
With
Hope this helps.
Yeah, makes sense, batching at works
