Exporting Package
Hello Guys,
I Am Having an Issue With FMOD. I Package My Project Then I Found That the Sound Is Not Working That Issue Is Only From FMOD Can Anyone Help Me To Fix This Issue. That Package For Android Please Help Me
What versions of FMOD and UE4 are you using?
Are you able to share the logs from the build and the built project?
UE4 Version 4.24.3
:woozy_face:
   LogFMOD: File has changed: ../../../../../Users/ankit/OneDrive/Documents/Unreal Projects/lighting/Content/FMOD/Desktop/Master.strings.bank
    LogFMOD: Loading strings bank: ../../../../../Users/ankit/OneDrive/Documents/Unreal Projects/lighting/Content/FMOD/Desktop/Master.strings.bank
    LogFMOD: Default sample rate = 48000
    LogFMOD: System sample rate = 192000
    LogFMOD: Warning: e:\jk\workspace\2.1_UE4.24_Win64\core_api\src\fmod_systemi.cpp(2812) - Output requires a sample rate of 192000Hz, resampling will occur.
    LogFMOD: Loading plugin 'C:\Users\ankit\OneDrive\Documents\FMOD Studio\Car1'
    LogFMOD: Trying to load plugin file at location: ../../../../../Users/ankit/OneDrive/Documents/Unreal Projects/lighting/Plugins/FMODStudio/Binaries/Win64/C:\Users\ankit\OneDrive\Documents\FMOD Studio\Car1.dll
    LogFMOD: Trying to load plugin file at location: ../../../../../Users/ankit/OneDrive/Documents/Unreal Projects/lighting/Plugins/FMODStudio/Binaries/Win64/C:\Users\ankit\OneDrive\Documents\FMOD Studio\Car164.dll
    LogFMOD: Error: Failed to load plugin 'C:\Users\ankit\OneDrive\Documents\FMOD Studio\Car1', sounds may not play
    LogSlate: Took 0.000203 seconds to synchronously load lazily loaded font '../../../Engine/Content/Slate/Fonts/Roboto-Light.ttf' (167K)
    LogAssetRegistry: Asset discovery search completed in 191.6849 seconds
    LogCollectionManager: Fixed up redirectors for 0 collections in 0.000010 seconds (updated 0 objects)
Plugins files need to be added to FMODStudio plugin directory, along side the FMOD libs for the required platforms.
https://fmod.com/resources/documentation-ue4?version=2.1&page=plugins.html
nhe did’t work
> LogFMOD: Trying to load plugin file at location: …/…/…/…/…/Users/ankit/OneDrive/Documents/Unreal Projects/lighting/Plugins/FMODStudio/Binaries/Win64/pitch.dll
LogFMOD: Trying to load plugin file at location: ../../../../../Users/ankit/OneDrive/Documents/Unreal Projects/lighting/Plugins/FMODStudio/Binaries/Win64/pitch64.dll
LogFMOD: Trying to load plugin file at location: ../../../../../Users/ankit/OneDrive/Documents/Unreal Projects/lighting/Plugins/FMODStudio/Binaries/Win64/pitch.dll
LogFMOD: Error: Failed to load plugin 'pitch', sounds may not play
It looks like it cannot find the plugin, can you confirm that the plugin “pitch.dll” is in that specific directory?
Hi Cameron,
Would you please help me with integrating FMOD to my game please?
Thank you in advance
Przemek
I would recommend using the User Guide to get started, then if you have any questions you can search through the forum or create a new topic.
