Unless I’m mistaken, currently if you have a big stack of transition regions and want to change their durations, I believe you have to drag each region separately. It would save a huge amount of time if you could select multiples and drag the beginnings or ends together.
You’re right: As of the time of writing (November of 2025), we support bulk editing the lengths of instruments, but not of logic regions. I can definitely see how being able to bulk edit the length of logic regions would be useful, so I’ll add your suggestion to our feature and improvement tracker.
Thanks so much. Always appreciate how response you all are to user input and feedback.
Just checking in to see if there’s any chance the “bulk drag” logic region duration change fix might be coming in a future update. It would really save a tremendous amount of time for certain types of complicated music events.
Looking at our records, the feature has not yet been scheduled for development or assigned a task priority. As such, I cannot predict when it might be released.
Related to this, but maybe should be requested separately, is the ability to bulk edit the offset for transition regions. Oftentimes there is a desire to set many of them to “none” or “relative” and right now it means clicking down a line of many transition regions and making the selection separately for each. If there was a way to select multiple and set them all to “relative” or “none” in one click that would be lovely.
I can see how being able to bulk edit the offset mode of transition regions would be useful. I’ll add your suggestion to our feature and improvement tracker.
