Hello there,
Can you even look at my code something can not be right since .
I always bekomm the error message FFT what nullptr .
#pragma comment(lib,"fmod64_vc.lib")
using namespace std;
FMOD::System* fmodSystem;
FMOD::Sound *music;
FMOD::Channel* musicChannel = 0;
FMOD_RESULT result;
FMOD::DSP *dsp1;
FMOD_DSP_PARAMETER_FFT *fft;
int fmodini()
if (FAILED(result = FMOD::System_Create(&fmodSystem))) {
MessageBox(NULL, "Failed", "Failed", MB_OK | MB_ICONEXCLAMATION);
if (FAILED(result = fmodSystem->init(32, FMOD_INIT_NORMAL, NULL))) {
if (FAILED(result = fmodSystem->createStream("Hawaii5O.mp3", FMOD_DEFAULT, 0, &music))) {
if (FAILED(result = fmodSystem->playSound(music, 0, false, &musicChannel))) {
fmodSystem->createDSPByType(FMOD_DSP_TYPE::FMOD_DSP_TYPE_FFT, &dsp1);
musicChannel->addDSP(FMOD_DSP_PARAMETER_DATA_TYPE_FFT, dsp1);
dsp1->getParameterData(FMOD_DSP_FFT_SPECTRUMDATA, (void **)fft, 0, 0, 0);
return 0;
Always in accessing the variable * fft I get the error message .
nick1
January 13, 2016, 11:36pm
#2
As a rule you should check the return code of all FMOD functions.
Channel::addDSP will be returning INVALID_PARAM because the first argument is wrong. It specifies the position in the DSP chain to add, not the DSP type.
Try
result = musicChannel->addDSP(FMOD_CHANNELCONTROL_DSP_HEAD, dsp1);
Which places the DSP at the head of the channels effect chain.
Thanks for the help.
I have modified the code and have carried out a test
the result.
float test = FFT > lenght ;
result = FFT > lenght < Unable to read memory >
result = FFT > numChannels < Unable to read memory >
fft was nullptr.
OK thanks for the help.
Have solved the problem .
When you enter this code
result = dsp1- > getParameterData ( FMOD_DSP_FFT_SPECTRUMDATA , (void ** ) & FFT , 0 , 0 , 0 ) ;
Must be a ( & ) character before the pointer ( * FFT ) are set .
Without it does not go with me .
I need a little help again .
I get all zeros as output .
if (FAILED(result = dsp1->getParameterData(FMOD_DSP_FFT_SPECTRUMDATA, (void **)&fft, 0, 0, 0))) {
MessageBox(NULL, “Failed”, “Failed”, MB_OK | MB_ICONEXCLAMATION);
for (int channel = 0; channel < fft->numchannels; channel++) {
for (int lenght = 0; lenght < fft->length; lenght++) {
fmoddata = fft->spectrum[channel][lenght];
result=fmodSystem->update();
Thank you have the problem found .
Did reading the data easy in the message loop in mainthread called and so the data is read continuously , and are no longer zero .
nick1
January 14, 2016, 11:58pm
#7
You need to let the sound play and read the spectrum continuously.
Whit this code,I get all zeros.
dsp1->setBypass(false);
dsp1->setActive(TRUE);
if (FAILED(result = fmodSystem->playSound(music, 0,FALSE, &musicChannel))) {
if (FAILED(result = fmodSystem->createDSPByType(FMOD_DSP_TYPE::FMOD_DSP_TYPE_FFT, &dsp1))) {
if (FAILED(result = musicChannel->addDSP(FMOD_DSP_PARAMETER_DATA_TYPE_FFT, dsp1))) {
if (FAILED(result = dsp1->getParameterData(FMOD_DSP_FFT_SPECTRUMDATA, (void **)&fft, 0, 0,0))) {
The sound runs.
