I seem to be getting a linker problem with FMOD_Channel_SetDelay.
FMOD_Channel_GetDelay seems to link fine.
(The calls to FMOD_Channel_SetDelay are inside extern “C” but within a .cpp file. All the other FMOD C-API calls compile and link fine.)
Am I missing something?
I’ve tried the 1.03.00 and 1.02.12 builds of FMOD Studio for Android with Android NDK r9c and Android SDK 19.0.1
Also FMOD_Channel_SetDelay has changed its syntax significantly between FMOD Studio 5 and FMOD Ex 4. Under FMOD 4 I was using FMOD_DELAYTYPE_DSPCLOCK_START and FMOD_DELAYTYPE_DSPCLOCK_END.
The new API has no delay type. Only dspclock_start and dspclock_end and a stopped flag. If I want to specify a start time for a channel, but not an end time I assume I set a value of 0 to dspclock_end.
   FMOD_Channel_SetDelay( pFmodChannel, (unsigned long long)dspClocktime, 0ull, false );
If I want to specify an end time for an already playing sound I assume I set a value of 0 to dsp_starttime.
   FMOD_Channel_SetDelay( pFmodChannel, 0ull, (unsigned long long)dspClocktime, true );
