FMOD error 37 World of Warcraft SESOUND
Hello, I’ve been playing World of Warcraft with Wine for a few days now, the only issue is that the sound of WoW isn’t working. While reviewing the SESOUND log, I came across the following:
3/27 22:43:50.860 => Version 3.3.5 (12340) Jun 24 2010
3/27 22:43:51.526
3/27 22:43:51.726 => Setting up Game Sound:
3/27 22:43:51.961 - SESound Engine Init
3/27 22:43:52.580 - FMOD Memory Init
3/27 22:43:52.768 - FMOD System Create
3/27 22:43:52.848 - FMOD version 00040907 detected
3/27 22:43:52.901 - Hardware is DISABLED
3/27 22:43:52.956 - Reverb is DISABLED
3/27 22:43:53.019 - 1 Output drivers detected
3/27 22:43:53.079 — [0] System Default
3/27 22:43:53.145 -######## FMOD ERROR! (err 37) An invalid parameter was passed to this function.
3/27 22:43:53.145 .\SoundEngine.cpp(2513)
3/27 22:43:53.245 -###########################################################################################
3/27 22:43:53.312 -######## FMOD ERROR! (err 37) An invalid parameter was passed to this function.
3/27 22:43:53.312 -######## ERROR INITIALIZING. ALL GAME SOUND DISABLED.
3/27 22:43:53.312 .\SoundEngine.cpp(2514)
3/27 22:43:53.356 -###########################################################################################
3/27 22:43:53.400 => Game Sound Init Failed.
3/27 22:43:53.456
Does anyone know if there’s a tool I need to install or something I need to do to make the sound work?
By the way, I’m using PulseAudio, and my winecfg configuration has the staging options ‘CSMT, VAAPI, and EAX’ enabled.
I have this same issue, hopefully you figured it out. I’m still looking for a solution.
