Here is my predicament - stock UE 4.15.2 has bug with Oculus Online Subsystem, where I can’t build release for distribution. However, that bug was fixed in Oculus 4.15.2 unified branch of UE4.
The problem is that Oculus 4.15.2 unified branch of UE4 doesn’t recognize FMOD plugin as supported and doesn’t load it.
So, I am pretty much stuck with a project I can not publish
Any idea what wouldn’t FMOD work with Oculus branch when it works perfectly fine with stock UE4 of the same version ?
The plugin needs to be recompiled (eg. in visual studio) when changing UE4 engine versions. Otherwise you could delete the plugin and copy in a fresh version.
If you have the plugin in the project directory, rebuilding the project will recompile the plugin.
Otherwise, if the plugin is in the engine directory, you will need to rebuild the engine. (Note: the plugin currently doesn’t work when in the UE4.15 engine directory)
I think the documentation is outdated and not applicable to current FMOD version.
“Delete the FMODStudio/Binaries/Platform/UE4*.* files. Leave the fmod libraries in the binaries directory!” << there is no Platforms/ folder. All platforms are loose in Binaries/ folder.
“Copy the plugin into YourGame/Plugins/FMODStudio” << What is “YourGame/” ? Is it root folder of the project folder? Is it “<Project_Name>/Content/Plugins/FMODStudio/” ? Either way FMOD source doesn’t appear in project’s solution after regenerating it
