FMOD.io inaccesible!
I’ve just installed FMOD Studio for the first time. I want to browse/purchase audio files via FMOD.io, but I cannot find any reference to FMOD.io anywhere: both the FMOD.io menu and Audio Bin window FMOD.io tab are completely absent! How do I access FMOD.io?! Please help. :frowning:
(I’m running the 32bit version of FMOD Studio on WinXP Pro).
FMOD.io is not compatible with Windows XP. If you want to use FMOD.io, you will have to upgrade to a more recent version of Windows or switch to a different operating system.
If you are unable to change operating systems at this time, one possible option is to install FMOD Studio on a machine running a different operating system, purchase and download the audio files you need, and then transfer them via disk or USB drive to your Windows XP machine.
We have no plans at this time to make FMOD.io compatible with Windows XP, as it is a rather old operating system: Microsoft officially discontinued support for Windows XP on the 8th of April, 2014, twelve years after it was released in 2001.
Ah, I thought that might be the case. I also have a Win 7 PC, so I’ll access FMOD.io on there.
Thanks for the feedback.
