It’s hard to grab a copy of the error text as it’s constantly updating, but this is what’s appearing in the console log.
Audio Driver: 4.0.9.2009 (Motu 828es)
This appears as MOTU Pro Audio in Fmod and Reaper.
Unity I believe just uses the whatever device WIndows 11 is using - i see nowhere in the settings to select an audio device in Unity
11:38:07 fmod_output_asio.cpp(99), OutputASIO::enumerate(): You can only have a single instance of ASIO active at a time.
11:38:07 “FMOD_ERROR (47): Error initializing output device, but more specifically, the output device is already in use and cannot be reused.”
11:38:07 “FMOD_ERROR C:\\buildagent1\\work\\c1c3f17eb167c494\\studio\\src\\SoundSystem.cpp(496): mSystem->update()”
