Hi, I’m testing the create programmer sound callback in fmodstudioL.js wasm 2.01.07. A sound ptr is successfully being created with queried audio table data, and all functions are returning FMOD.OK, but even after setting the sound and subsoundIndex parameters no sound is being produced.
Creating a programmer sound from a local midi file is working correctly, so this is why I thought it possibly might be a JS/HTML5 audio table support issue. Also my desktop implementation using the same calls in cpp is working fine as well.
I can share my code if needed.
Thank you for your help.
