FMOD Studio version 1.06.05
Android ARM, Lollipop, Samsung Galaxy S5
Running a NativeActivity with a simple class wrapper to call System.loadLibrary(“fmodL”)
and invoke org.fmod.FMOD.init()
library loads successfully, org.fmod.FMOD.init() succeeds
In native code (after library successfully loaded and initialized)
FMOD::Debug_Initialize succeeds
FMOD::System_Create succeeds
system->getVersion() succeeds
system->getNumDrivers() returns FMOD_ERR_PLUGIN_MISSING
from the error log:
I/fmod (32589): [ERR] FMOD_OS_Output_GetDefault : JavaVM::GetEnv returned -2.
FMOD source file/line number for the error is
…/android/src/fmod_os_output.cpp(52)
The native code is getting invoked from the main application thread that the NativeActivity is running on.
It doesn’t seem like I’m doing anything crazy here but it’s not working.
Is there an initialization step I’m missing or something?
This application was working fine with FModEX. I upgraded to pick up the ARM64 support and have been having problems getting back to a running state since.
additional data point: calling system->setOutput to avoid the check for default output type lets the app get further along before failing but the log indicates the underlying issues are related to the JVM failing to provide environment info.
log excerpt:
D/BEngine ( 2253): SoundDevice.cpp(54): TRACE: fmod shared lib version: 00010605
D/BEngine ( 2253): SoundDevice.cpp(83): TRACE: 1 sound drivers available.
I/fmod ( 2253): [ERR] OutputOpenSL::getDriverInfo : JavaVM::GetEnv returned -2.
D/BEngine ( 2253): SoundDevice.cpp(99): TRACE: Using device Android audio output
I/fmod ( 2253): [ERR] AndroidAssetFile::registerLib : JavaVM::GetEnv returned -2.
I/fmod ( 2253): [ERR] OutputOpenSL::init : JavaVM::GetEnv returned -2.
W/BEngine ( 2253): SoundDevice.cpp(121): FMOD error: An error occurred that wasn’t supposed to. Contact support. (28)
