Fmod声音怎么使用淡入淡出效果啊!这个是程序员来调试效果还是Fmod自带有这个淡入淡出效果?
Fmod 编辑器支持声音淡入淡出效果吗?
It depends what you mean by “fade effect”. If you are simply looking for a way to slowly fade the volume of an event or bus in or out, it is worth looking into using snaphots. Scope the event’s bus into the snapshot and when you need to fade, play the snapshot like an event. For more information, please check out our documentation:
