No "fade In/out" options in blueprints for Fmod event
Hi When I use wav file, I can easily put fade in/out in blueprints but when i use fmod event there is no options, I can only put play
http://imgup.pl/di/CABV/f1.png
http://imgup.pl/di/I5KI/f2.png
Why:(??
You can also create fade-in behavior within the FMOD event itself. That way you don’t even need to worry about doing it in BluePrints.
So my music is playing, in certain place i want to trigger it to fade out. What should i do?
thx
If you have an active music event playing at all times and you want to lower it at a certain location? There are a few ways to go about this, it depends on what your end goal is.
WHat you may want to do is, assign the music event to a Bus Channel in FMOD the use the ButSetFaderLevel node in UE4 to drive the volume of the channel. You can use a volume trigger to send the overlap event
As JB has said, there are a few ways to go about this.
Another way could be using parameters and automation inside studio to control volume levels that can then be set via triggers for example.
Thx guys.
Parametr, triger box and volume automation works fine besides i found “smoothing”, when You click on paramter twice. Now I can fade out my music for 5 seconds
