Get Programmer Instrument Sound Length
I’m using a programmer instrument together with an audio table to play music inside my cassette player and I want to display the duration of the played track, currently “played time” works but I can’t seem to get the total length of the track.
I’ve been reading on the forum and the closest I got was this post:
https://qa.fmod.com/t/get-length-duration-of-programmer-instrument-audio-table-loaded-sound/13911
Following the post above I get the correct subSound index based on the audio table but I can’t get the length to work consistently, it works like 1/20 times for some reason?
Here’s the full callback:
[AOT.MonoPInvokeCallback(typeof(EVENT_CALLBACK))]
static RESULT PlayMusicEventCallback(EVENT_CALLBACK_TYPE type, EventInstance eventInstance, IntPtr parameterPtr)
	// Retrieve the user data
	eventInstance.getUserData(out var stringPtr);
	// Get the string object
	GCHandle stringHandle = GCHandle.FromIntPtr(stringPtr);
	string key = stringHandle.Target as string;
	switch (type)
		case EVENT_CALLBACK_TYPE.CREATE_PROGRAMMER_SOUND:
			const MODE soundMode = MODE.LOOP_OFF | MODE.CREATESTREAM | MODE.NONBLOCKING;
			var parameter = (PROGRAMMER_SOUND_PROPERTIES) Marshal.PtrToStructure(parameterPtr, typeof(PROGRAMMER_SOUND_PROPERTIES));
			var keyResult = RuntimeManager.StudioSystem.getSoundInfo(key, out var musicSoundInfo);
			if (keyResult != RESULT.OK)
				break;
            // Attempt to get the track's length!
			var soundResult = RuntimeManager.CoreSystem.createSound(musicSoundInfo.name_or_data, soundMode | musicSoundInfo.mode, ref musicSoundInfo.exinfo, out Sound musicSound);
			Sound subSound;
			musicSound.getSubSound(musicSoundInfo.subsoundindex, out subSound);
			uint length = 0;
			subSound.getLength(out length, FMOD.TIMEUNIT.MS);
			CassettePlayer.instance.SetMaxTrackDuration(length);
			Debug.Log(length);
			if (soundResult == RESULT.OK)
				parameter.sound = musicSound.handle;
				parameter.subsoundIndex = musicSoundInfo.subsoundindex;
				Marshal.StructureToPtr(parameter, parameterPtr, false);
			else
				Debug.LogError("Error creating sound!");
			break;
		case EVENT_CALLBACK_TYPE.DESTROY_PROGRAMMER_SOUND:
			var sound = new Sound {handle = parameter.sound};
			sound.release();
			break;
		case EVENT_CALLBACK_TYPE.DESTROYED:
			// Now the event has been destroyed, unpin the string memory so it can be garbage collected
			stringHandle.Free();
			break;
	return RESULT.OK;
subSound.getLength (as well as musicSound.getSubSound) will return an FMOD.RESULT that could indicate why it isn’t working.
I’m getting an ERR_NOTREADY result from the getSubSound, might be because we’re streaming the audio using MODE.CREATESTREAM?
Here’s code snipped again (runs inside CREATE_PROGRAMMER_SOUND callback)
Sound subSound;
RESULT result = musicSound.getSubSound(musicSoundInfo.subsoundindex, out subSound);
if (result != RESULT.OK)
	Debug.LogError(result.ToString());
else
	uint length = 0;
	result = subSound.getLength(out length, FMOD.TIMEUNIT.MS);
	else
This is because you are using NONBLOCKING when you create the sound:
System::createSound
Use FMOD_NONBLOCKING to have the sound open or load in the background. You can use Sound::getOpenState to determine if it has finished loading / opening or not. While it is loading (not ready), sound functions are not accessible for that sound.
Using LateUpdate to check if Sound::getOpenState == OK fixed my issue, Thanks Cameron!
Here’s the code:
// Inside LateUpdate switch case logic
var result = musicSound.getOpenState(out var openState, out _, out _, out _);
if (result == RESULT.OK)
	if (openState != OPENSTATE.ERROR)
		musicSound.getSubSound(subSoundIndex, out var subSound);
		// Wait until the length have been fetched!
		result = subSound.getLength(out var length, FMOD.TIMEUNIT.MS);
			CassettePlayer.instance.SetMaxTrackDuration((int) length);
			gotMaxLength = true;
Thank you both for posting this - was having issues with getting length and thought one reason might be because it wasn’t ready (among a few other reasons I had listed to test). This was super helpful in quickly solving that!
