I am working on a music system with orchestral layers and I tried using transition regions to go from one region to another, but when transitioning it doesn’t sound smooth and cuts off my strings before transitioning. I also can’t find video’s that explains this.
Would appreciate any advice.
I just want to have the transitions go as smooth as here for example:
I’m afraid the video you posted appears as a “this video is unavailable” message, to me.
In any case, we’ll need more information about the structure of your event if we’re to understand its current behavior and suggest ways of altering it to achieve the behavior you want. Are you able to post some screenshots of the event, so that we can see its content?
Drag the right edge of the transition region to activate the transition timeline. Then, drag the white bracket on the left side of the tracks to extend the source region. Then, add a fade out (by hovering on the right corner or the source region). This will let the source regions to fade out while you are transitioning to the destination. Remember to also extend the destination handles crossing the start of the fade.
