How to change the loop state before playback using Unity code?
I know that in FMOD Studio, you can set up a loop by using Add Loop Region.
However, if the loop is not set in FMOD Studio, I would like to know how to enable or disable looping directly through Unity code.
Currently, I am playing the sound like this:
I will paste part of the code below.
private FMOD.Studio.EventDescription eventDescription;
if (eventDescription.isValid())
            instance = GetInstance();
            await WaitForChannelGroup(instance);
            if (instance.isValid() && is3D)
#if UNITY_PHYSICS_EXIST
                if (target.GetComponent<Rigidbody>())
                    Rigidbody rigidBody = target.GetComponent<Rigidbody>();
                    RuntimeManager.AttachInstanceToGameObject(instance, target, rigidBody);
                    instance.set3DAttributes(RuntimeUtils.To3DAttributes(target, rigidBody));
                else
#endif
#if UNITY_PHYSICS2D_EXIST
                if (target.GetComponent<Rigidbody2D>())
                    var rigidBody2D = target.GetComponent<Rigidbody2D>();
                    RuntimeManager.AttachInstanceToGameObject(instance, target, rigidBody2D);
                    instance.set3DAttributes(RuntimeUtils.To3DAttributes(target, rigidBody2D));
                else
#endif
                    RuntimeManager.AttachInstanceToGameObject(instance, target);
                    instance.set3DAttributes(RuntimeUtils.To3DAttributes(target));
if (instance.isValid())
            instance.start();
An option may be using FMOD Engine | Studio API Reference - EventInstance::setTimelinePosition.
Something like this:
if (eventInstance.isValid())
    FMOD.RESULT result = eventInstance.getTimelinePosition(out int position);
    if (result == FMOD.RESULT.OK)
        if (position >= 10000 /* This is the target loop point */)
            result = eventInstance.setTimelinePosition(0); /* Loop back to the start of the event */
            if (result != FMOD.RESULT.OK)
                Debug.LogError($"Failed to loop event with error: {result}");
    else
        Debug.LogError($"Failed to get timeline position: {result}");
However, these isn’t a way to create a new FMOD Studio loop region from within Unity.
Thank you for your reply.
I don’t want to adjust the loop region.
There are some audio clips that I want to keep playing in Unity with looping enabled, even if no loop settings were made in the studio.
I would like to configure this via code.
Is it impossible?
I see, thank you for the clarification.
An option could be using the event callback FMOD Engine | Studio API Reference - FMOD_STUDIO_EVENT_CALLBACK_STOPPED and restarting the event instance from there? We have scripting example implementing a callback here: Unity Integration | Scripting Examples - Programmer Sounds.
Hope this helps
