Importing Opus ogg format not supported?
I have thousands of audio file encoded in Opus codec in ogg container, upon importing such file, FMOD studio failed to recognize as audio file and error popups saying, “[audioPath.ogg] is not a supported audio file”. it would be hassle to re-encode all one by one. please let me know if there is any can be done. thankyou
MediaInfo:
Format : Ogg
File size : 1 004 KiB
Duration : 36 s 7 ms
Overall bit rate : 228 kb/s
Writing application : Lavc61.19.100 libopus
Audio
ID : 811300851 (0x305B77F3)
Format : Opus
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Compression mode : Lossy
Writing library : Lavf61.7.100
Thank you for sharing the information.
Currently, FMOD Studio only supports the Vorbis codec for .ogg files.
Totally understandable. In this case, you might consider using free online tools that support batch audio conversion. While I can’t point you to a specific tool directly, there are quite a few out there, and a quick online search should help you find something that suits your workflow.
Hope this helps, let me know if you have questions.
I thought if it was a bug, I’ll consider re-encoding then.
thankyou for clarification.
