Alco6
1
I am trying to use the Low Level API on Unity. However when I play there is no sound at all.
- I have disabled Unity Audio in Project Sett
private void InitFMODLowLevel()
FMOD.Factory.System_Create(out FMODsystem);
FMODsystem.setOutput(FMOD.OUTPUTTYPE.WASAPI);
FMODsystem.init(512, FMOD.INITFLAGS.NORMAL, System.IntPtr.Zero);
void PlaySoundLowLevel(float noteFreq, float duration )
FMOD.CREATESOUNDEXINFO sInfo = new FMOD.CREATESOUNDEXINFO();
sInfo.length = (uint)duration; //sound.Length
sInfo.format = FMOD.SOUND_FORMAT.PCMFLOAT;
sInfo.defaultfrequency = 44100;
sInfo.numchannels = 1;
sInfo.cbsize = Marshal.SizeOf(typeof(FMOD.CREATESOUNDEXINFO));
FMOD.Sound FMODSound;
byte[] Signal= CreateSound( noteFreq, duration);
FMODsystem.createSound(Signal, FMOD.MODE.DEFAULT,ref sInfo,out FMODSound);
FMOD.ChannelGroup masterChannelGroup;
FMODsystem.getMasterChannelGroup(out masterChannelGroup);
FMODsystem.playSound(FMODSound, masterChannelGroup, false, out FMODChannel);
Could you please tell me where could be the problem? I receive no error on the console but there is no sound.
mathew
2
Firstly, I’d recommend you check the error codes returned from each FMOD function, that should give you an idea where your error is.
Looking at your sample, I’d say createSound is failing because you need to pass in FMOD.MODE.OPEN_MEMORY.
Alco6
3
I tried OPEN_MEMORY and OPENUSER, I get errors with all different combinations from createSound
FmodERRCheck(FMODsystem.createSound(Signal, (FMOD.MODE.OPENUSER| FMOD.MODE.OPENMEMORY), ref sInfo, out FMODSound));
Signal is a byte[] generated sinewave.
byte[] Signal= CreateSoundSignal( noteFreq, duration);
///Channel configuration
FmodERRCheck(FMODsystem.getMasterChannelGroup(out masterChannelGroup));
FMOD.Channel FMODChannel;
FmodERRCheck(FMODsystem.playSound(FMODSound, masterChannelGroup, false, out FMODChannel));
public static byte[] CreateSoundSignal(float noteFreq, float time)
int sampleFreq = 44100;
int sampleTime = Mathf.RoundToInt(sampleFreq * time);
float[] samples = new float[sampleTime];
for (int i = 0; i < samples.Length; i++)
samples[i] = Mathf.Sin(Mathf.PI * 2 * i * noteFreq / sampleFreq);
byte[] byteSamples = new byte[samples.Length * sizeof(float)];
Buffer.BlockCopy(samples, 0, byteSamples, 0, byteSamples.Length);
return byteSamples;
mathew
4
Instead of OPENUSER, try OPENRAW.
So FMOD.MODE.OPENRAW | FMOD.MODE.OPENMEMORY
