Hey guys,
is there any way to load and Unity AudioClip as an fmod sound like we do with FMOD.System.createSound(“sound.wav”) ? I was trying to convert the audio clip to a bytearray and get just the raw data, but it hasn’t work.
Any other approaches suggested?
Thanks.
nick1
December 3, 2014, 5:59am
2
using UnityEngine;
using System.Collections;
using System;
public class clip_to_sound : MonoBehaviour
public AudioClip audioclip;
FMOD.Channel channel;
void Start ()
float[] samples = new float[audioclip.samples * audioclip.channels];
audioclip.GetData(samples, 0);
FMOD.System lowlevel = null;
FMOD_StudioSystem.instance.System.getLowLevelSystem(out lowlevel);
uint lenbytes = (uint)(audioclip.samples * audioclip.channels * sizeof(float));
FMOD.CREATESOUNDEXINFO soundinfo = new FMOD.CREATESOUNDEXINFO();
soundinfo.length = lenbytes;
soundinfo.format = FMOD.SOUND_FORMAT.PCMFLOAT;
soundinfo.defaultfrequency = audioclip.frequency;
soundinfo.numchannels = audioclip.channels;
FMOD.RESULT result;
FMOD.Sound sound;
result = lowlevel.createSound("", FMOD.MODE.OPENUSER, ref soundinfo, out sound);
IntPtr ptr1, ptr2;
uint len1, len2;
result = sound.@lock(0, lenbytes, out ptr1, out ptr2, out len1, out len2);
Marshal.Copy(samples, 0, ptr1, (int)(len1 / sizeof(float)));
if (len2 > 0)
Marshal.Copy(samples, (int)(len1 / sizeof(float)), ptr2, (int)(len2 / sizeof(float)));
result = sound.unlock(ptr1, ptr2, len1, len2);
result = sound.setMode(FMOD.MODE.LOOP_NORMAL);
result = lowlevel.playSound(sound, null, false, out channel);
Xuan
January 9, 2018, 10:34am
3
using UnityEngine;
using System;
void Start ()
FMOD.RESULT result;
FMOD.Sound sound;
IntPtr ptr1, ptr2;
uint len1, len2;
if (len2 > 0)
I have a confuse that why not use “Factory.System_Create(out lowlevel)” but “getLowLevelSystem(out lowlevel)”
The StudioSystem will already contain a LowLevel System and this will give you a reference to it, System_Create will make a new LowLevel System separate from the one you are already using.
Xuan
January 10, 2018, 3:01am
5
Thanks!But I can’t create the current sound,it’s handle’s value always equals 0,I don’t know why.
Xuan
January 10, 2018, 3:06am
6
ps:The parametric “name” of createSound is the path of music likes “d:/AAA/touch.mp3”, Is’t correct ?
That is correct.
This Q&A is for the older legacy Unity Integration for FMOD Ex and will be different for the latest versions, although not a lot will need to change.
To get the LowLevel system use:
FMOD.System lowlevelsystem = FMODUnity.RuntimeManager.LowlevelSystem;
