Unity integration for low level API only (no FMOD studio)
I would like to use FMOD in Unity only for using low level API. But every time I run my project, there is an error saying “FMOD Studio project path not set”. How do I need to integrate FMOD with Unity for using low level API only?
To use the low-level only you would remove every file apart from the native library files and the files under Assets/Plugins/FMOD/Wrapper
You will need to handle the initialization of FMOD low-level system at startup yourself.
