Hello. I’m currently developing a DSP plugin for Fmod.
The plugin consists of audio processes A and B.
I would like to send a signal to a bus after incoming audio is processed with A but before B and I don’t want to split the plugin into two plugins.
My question is would it be possible to access the bus structure from C++ API?
Unfortunately this is not possible, you would need to use two separate plugins.
