MIDI Files
Can I use a midi file within Fmod Studio?
I would like to be able to play a sequence on a sound, and also change it’s speed and transpose via a parameter.
Hi Jeff,
MIDI files are supported in the low level API, which you could trigger as a programmer sound in fmod studio.
It wouldnt be via a parameter, but in the low level code there is a function that allows the speed to change
class Sound
    FMOD_RESULT F_API setMusicSpeed          (float speed);
    FMOD_RESULT F_API getMusicSpeed          (float *speed);
regards,
