Still some issues with the 1.03.07. Everything works fin in unity player, but there’s something missing in the IOS library (libfmodstudiounityplugin.a) of the latest build. Getting a lot of linker issues.
"_FMOD_System_MixerSuspend", referenced from:
RegisterMonoModules() in RegisterMonoModules.o
"_FMOD_System_MixerResume", referenced from:
"_FMOD_System_GetDSPInfoByPlugin", referenced from:
"_FMOD_Reverb3D_SetUserData", referenced from:
"_FMOD_Reverb3D_SetProperties", referenced from:
"_FMOD_Reverb3D_Set3DAttributes", referenced from:
"_FMOD_Reverb3D_Release", referenced from:
"_FMOD_Reverb3D_GetProperties", referenced from:
"_FMOD_DSP_SetParameterFloat", referenced from:
"_FMOD_System_AttachChannelGroupToPort", referenced from:
"_FMOD_DSP_SetParameterBool", referenced from:
"_FMOD_DSP_SetMeteringEnabled", referenced from:
"_FMOD_DSP_GetParameterInt", referenced from:
"_FMOD_DSP_GetParameterFloat", referenced from:
"_FMOD_DSP_GetParameterBool", referenced from:
"_FMOD_DSP_GetMeteringInfo", referenced from:
"_FMOD_DSP_GetMeteringEnabled", referenced from:
"_FMOD_DSP_GetIdle", referenced from:
"_FMOD_DSP_SetParameterData", referenced from:
"_FMOD_DSP_GetDataParameterIndex", referenced from:
"_FMOD_DSP_GetChannelFormat", referenced from:
"_FMOD_ChannelGroup_GetLowPassGain", referenced from:
"_FMOD_ChannelGroup_Set3DAttributes", referenced from:
"_FMOD_DSPConnection_SetMixMatrix", referenced from:
"_FMOD_ChannelGroup_Set3DDopplerLevel", referenced from:
"_FMOD_DSPConnection_GetMixMatrix", referenced from:
"_FMOD_ChannelGroup_SetReverbProperties", referenced from:
"_FMOD_ChannelGroup_SetVolumeRamp", referenced from:
"_FMOD_ChannelGroup_SetMixMatrix", referenced from:
"_FMOD_Reverb3D_SetActive", referenced from:
"_FMOD_ChannelGroup_SetMixLevelsOutput", referenced from:
"_FMOD_System_DetachChannelGroupFromPort", referenced from:
"_FMOD_ChannelGroup_SetMixLevelsInput", referenced from:
"_FMOD_ChannelGroup_SetDSPIndex", referenced from:
"_FMOD_ChannelGroup_RemoveDSP", referenced from:
"_FMOD_DSPConnection_GetType", referenced from:
"_FMOD_ChannelGroup_Set3DSpread", referenced from:
"_FMOD_ChannelGroup_SetDelay", referenced from:
"_FMOD_ChannelGroup_Set3DConeSettings", referenced from:
"_FMOD_ChannelGroup_Set3DDistanceFilter", referenced from:
"_FMOD_ChannelGroup_Set3DConeOrientation", referenced from:
"_FMOD_ChannelGroup_SetPan", referenced from:
"_FMOD_Reverb3D_GetUserData", referenced from:
"_FMOD_ChannelGroup_IsPlaying", referenced from:
"_FMOD_ChannelGroup_Get3DConeSettings", referenced from:
"_FMOD_Sound_GetSubSoundParent", referenced from:
"_FMOD_DSP_GetOutputChannelFormat", referenced from:
"_FMOD_ChannelGroup_Set3DCustomRolloff", referenced from:
"_FMOD_ChannelGroup_Get3DMinMaxDistance", referenced from:
"_FMOD_ChannelGroup_GetNumDSPs", referenced from:
"_FMOD_ChannelGroup_Get3DAttributes", referenced from:
"_FMOD_ChannelGroup_GetFadePoints", referenced from:
"_FMOD_ChannelGroup_Set3DLevel", referenced from:
"_FMOD_ChannelGroup_GetDelay", referenced from:
"_FMOD_ChannelGroup_GetDSP", referenced from:
(maybe you meant: _FMOD_ChannelGroup_GetDSPHead)
"_FMOD_ChannelGroup_GetVolumeRamp", referenced from:
"_FMOD_ChannelGroup_GetAudibility", referenced from:
"_FMOD_ChannelGroup_GetDSPIndex", referenced from:
"_FMOD_ChannelGroup_SetLowPassGain", referenced from:
"_FMOD_ChannelGroup_Get3DLevel", referenced from:
"_FMOD_ChannelGroup_Get3DDopplerLevel", referenced from:
"_FMOD_System_GetSpeakerPosition", referenced from:
"_FMOD_ChannelGroup_SetCallback", referenced from:
"_FMOD_ChannelGroup_Get3DConeOrientation", referenced from:
"_FMOD_DSP_GetParameterData", referenced from:
"_FMOD_ChannelGroup_Set3DMinMaxDistance", referenced from:
"_FMOD_System_SetSpeakerPosition", referenced from:
"_FMOD_Reverb3D_Get3DAttributes", referenced from:
"_FMOD_ChannelGroup_RemoveFadePoints", referenced from:
"_FMOD_ChannelGroup_GetDSPClock", referenced from:
"_FMOD_System_CreateReverb3D", referenced from:
"_FMOD_ChannelGroup_Get3DDistanceFilter", referenced from:
"_FMOD_ChannelGroup_AddFadePoint", referenced from:
"_FMOD_DSP_SetChannelFormat", referenced from:
"_FMOD_ChannelGroup_GetReverbProperties", referenced from:
"_FMOD_ChannelGroup_Get3DCustomRolloff", referenced from:
"_FMOD_Reverb3D_GetActive", referenced from:
"_FMOD_DSP_SetParameterInt", referenced from:
"_FMOD_ChannelGroup_GetMixMatrix", referenced from:
"_FMOD_ChannelGroup_Get3DSpread", referenced from:
ld: symbol(s) not found for architecture armv7
clang: error: linker command failed with exit code 1 (use -v to see invocation)
