So I’m a bit confused on the limitations/requirements of the geometry engine.
I’ve been playing with a few algorithms for binary voxel grid → mesh conversion (Marching Cubes and Surface Nets mainly) but I keep getting errors from FMOD telling me I’m passing invalid parameters. Either that, or it doesn’t create the geometry when I call createGeometry and returns an error there. Does FMOD enforce requirements like “there must not be degenerate polygons/vertices” or something? My code is (API wise) doing everything correctly, but for some reason FMOD is really not liking the vertices I’m passing in.
