Mp3 is not playable in FMOD
Here’s an mp3 that can’t be played with FMOD 2.02.06.
It’s playable on some software and not recognized in others. Is it corrupt or what’s going on?
And this one is playable in most players, but not FMOD:
Are you using FMOD Core API?
If so fmod does not spend extra effort to scan corrupt files.
You can use FMOD_MPEGSEARCH to scan through the bad data until it finds valid mp3 data.
Yes, that worked, thanks!
It was truly useful! Without an inquiry, I’ve just barely begun, yet I’m finding out increasingly more about it. Much obliged to you for being benevolent, and proceed with the astounding exertion.
