Hey! I’m struggling to figure out how to get this setup to work: I have a radio object which I can interact with in Unity, and I want this interact to toggle between muting and unmuting a continuously playing FMOD event. How would I implement this?
I’m quite new to FMOD Unity by the way
Thank you for sharing the information.
If your radio object is using a StudioEventEmitter, a simple way is to toggle the volume of its event instance when the object is interacted with.
For example:
using UnityEngine;
using FMODUnity;
public class RadioMuteToggle : MonoBehaviour
public StudioEventEmitter radioEmitter;
private bool muted;
private void Update()
// press P to test mute/unmute
if (Input.GetKeyDown(KeyCode.P))
Interact();
public void Interact()
muted = !muted;
radioEmitter.EventInstance.setVolume(muted ? 0f : 1f);
Add this script to your radio object, assign the same StudioEventEmitter to radioEmitter, then press P to test it. In your own project, you can call Interact() from your interaction system instead.
This mutes/unmutes the radio while the event keeps playing in the background.
If you want the radio to pause instead, you can use Studio::EventInstance::setPaused instead of Studio::EventInstance::setVolume in Interact().
For example:
radioEmitter.EventInstance.setPaused(muted);
