n00b needing help with Android error
I’m seeing an error that appears to be related to FMOD trying to load something.
The error is below:
10-05 04:00:54.641: I/Unity(21391): AndroidJavaException:
java.lang.UnsatisfiedLinkError: dlopen failed: cannot locate symbol
“__aeabi_atexit” referenced by
“/data/app/com.bsgbryan.jumpymcrunface-2/lib/arm/libfmod.so”…
Full disclosure: I’m an Android n00b. I have the Android SDK, Java JDK, and Android NDK installed and configured in Unity. My game builds properly on iOS/tvOS/macOS devices. I’m just getting the above error when I run my game on my test Nexus 5.
I’ve googled around and can’t find anything related to this specifically.
Versions for everything I’m using:
FMOD Studio: 1.08.11, 64 bit, Build #79819
Unity: 5.4.1f1
Device: Nexus 5 running Android 6.0.1
In unity, I have the minimum Android version set to: 4.1 ‘Jelly Bean’ API level 16
I’d really appreciate any help, thanks!
And if there’s any additional info you need, please just let me know!
This is known issue with our 1.08.11 release, please update to 1.08.12 or newer.
