Hii can someone help me how do i import fl studio intrumental project to fmod ?
You can only import audio files into FMOD. If you want to have your instrumental track in FMOD then you should look up how to make adaptive music. Or, simply export your track as audio and import that into an event in FMOD.
hey another question will i be able to use a audio game soundcard for fmod
I can’t see why not. FMOD can see all your outputs (I know it can see the same outputs that my computer can see) so you’d be able to select the soundcard as your audio device
