Hey,
I´ve got a 7.1 usb Sound Card for my Raspberry Pi 3 (Using FMOD5 Low Level API with C++).
$ amixer -c1 scontents
gives
Simple mixer control ‘Speaker’,0
Capabilities: pvolume pswitch pswitch-joined
Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front Center - Woofer - Side Left - Side Right
Limits: Playback 0 - 197
Mono:
Front Left: Playback 197 [100%] [0.00dB] [on]
Front Right: Playback 197 [100%] [0.00dB] [on]
Rear Left: Playback 197 [100%] [0.00dB] [on]
Rear Right: Playback 197 [100%] [0.00dB] [on]
Front Center: Playback 197 [100%] [0.00dB] [on]
Woofer: Playback 197 [100%] [0.00dB] [on]
Side Left: Playback 197 [100%] [0.00dB] [on]
Side Right: Playback 197 [100%] [0.00dB] [on]
Simple mixer control ‘PCM’,0
Capabilities: cvolume cswitch cswitch-joined
Capture channels: Front Left - Front Right
Limits: Capture 0 - 6928
Front Left: Capture 4096 [59%] [-0.01dB] [on]
Front Right: Capture 4096 [59%] [-0.01dB] [on]
Simple mixer control ‘PCM Capture Source’,0
Capabilities: enum
Items: ‘Mic’ ‘Line’ ‘IEC958 In’ ‘Mixer’
Item0: ‘Mic’
Simple mixer control ‘Line’,0
Capabilities: pvolume cvolume pswitch pswitch-joined cswitch cswitch-joined
Limits: Playback 0 - 8065 Capture 0 - 6928
Front Left: Playback 6144 [76%] [-0.01dB] [off] Capture 0 [0%] [-16.00dB] [off]
Front Right: Playback 6144 [76%] [-0.01dB] [off] Capture 0 [0%] [-16.00dB] [off]
Simple mixer control ‘Mic’,0
Front Left: Playback 6144 [76%] [-0.01dB] [on] Capture 4096 [59%] [-0.01dB] [on]
Front Right: Playback 6144 [76%] [-0.01dB] [on] Capture 4096 [59%] [-0.01dB] [on]
Simple mixer control ‘IEC958 In’,0
Capabilities: cswitch cswitch-joined
Capture channels: Mono
Mono: Capture [on]
and
$ speaker-test -c 6 -D surround40 -t wav
works too.
But FMOD only detects stereo channels.
int num_drivers;
result = m_music_system->getNumDrivers(&num_drivers);
if (result != FMOD_OK)
printf("FMOD ERROR\n");
print_fmod_error(result);
exit(-1);
for (int i = 0; i < num_drivers; i++) {
char name[50];
int name_len = 0;
FMOD_GUID guid = FMOD_GUID();
int system_rate = 0;
FMOD_SPEAKERMODE speaker_mode = FMOD_SPEAKERMODE_DEFAULT;
char* str_speaker_mode;
int speaker_mode_channels = 0;
result = m_music_system->getDriverInfo(i, name, name_len, &guid, &system_rate, &speaker_mode, &speaker_mode_channels);
exit(-1);
switch (speaker_mode) {
case FMOD_SPEAKERMODE_DEFAULT: str_speaker_mode = " Default speaker mode based on operating system/output mode. Windows = control panel setting, Xbox = 5.1, PS3 = 7.1 etc. "; break;
case FMOD_SPEAKERMODE_RAW: str_speaker_mode = " There is no specific speakermode. Sound channels are mapped in order of input to output. Use System::setSoftwareFormat to specify speaker count. See remarks for more information. "; break;
case FMOD_SPEAKERMODE_MONO: str_speaker_mode = " The speakers are monaural. "; break;
case FMOD_SPEAKERMODE_STEREO: str_speaker_mode = " The speakers are stereo. "; break;
case FMOD_SPEAKERMODE_QUAD: str_speaker_mode = " 4 speaker setup. This includes front left, front right, surround left, surround right. "; break;
case FMOD_SPEAKERMODE_SURROUND: str_speaker_mode = " 5 speaker setup. This includes front left, front right, center, surround left, surround right. "; break;
case FMOD_SPEAKERMODE_5POINT1: str_speaker_mode = " 5.1 speaker setup. This includes front left, front right, center, surround left, surround right and an LFE speaker. "; break;
case FMOD_SPEAKERMODE_7POINT1: str_speaker_mode = " 7.1 speaker setup. This includes front left, front right, center, surround left, surround right, back left, back right and an LFE speaker. "; break;
case FMOD_SPEAKERMODE_MAX: str_speaker_mode = " Maximum number of speaker modes supported. "; break;
case FMOD_SPEAKERMODE_FORCEINT: str_speaker_mode = " Makes sure this enum is signed 32bit. "; break;
char n_name[name_len];
for (int j = 0; j < name_len; j++) {
n_name[j] = name[j];
printf("%s-%s-%d\n", n_name, str_speaker_mode, speaker_mode_channels);
prints
�- The speakers are stereo. -2
ALSA lib pcm_dsnoop.c:557:(snd_pcm_dsnoop_open) The dsnoop plugin supports onl
y capture stream
y capture stream
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection
refused
y capture stream
Any way to fix this? Any futher information I can provide?
Thanks for help ![]()
