PlayAudio Script
I am sound designer not programmer and i need Yor help. I am adding footsteps to 3rd person character.
I made simple script in Java and put it into animation events as function. It works very well.
What i need is someone to help me with adding “random pitch function” to my script.
Also is there a tut how to do it with FMOD? Viking Villiage shows only 1st person character
thanks
What do you mean by adding “random pitch function”.
Are you using the pitch control in Studio at all?
Hi
I found answer, this is tut showing 3 person character animation events:
This function allows to use FMOD event in “Animation events”:
using System.Collections;
using UnityEngine;
public class Footsteps : MonoBehaviour {
// Use this for initialization
void PlaySound(string path)
	FMODUnity.RuntimeManager.PlayOneShot(path, GetComponent<Transform> ().position);
void Update () {
