Hi everyone! I’m new to this forum and glad to be part of the FMOD community.
I was wondering if there’s a way to prevent the spatializer from reducing the event stereo width/spread by default, even when the listener’s distance from the emitter equals 0.
As an example, I set up an event for a waterfall emitter that needs to be spatialized. But even when the listener is close to the waterfall (say, between 0 to 5 meters away), FMOD narrows the stereo width of the event. However, this is not the behavior I would expect. Instead, I’d like the waterfall width to be maximum when the listener is within the event minimum distance range and narrowed as the listener moves away from it. Is there a workaround for that?
Thanks everyone for your time and support! Have a great day,
Simone
