problem of FMOD_System_playsound
i downloaded FMOD Studio for Unreal Engine 4 (4.13)
1-i didn’t find the flag (fmod_channel_free)
2-the proramm didn’t work
3-in built message i see:
warnig:passing argument 2 of ‘FMOD_Syste_playsound’ makes pointer from integer without a cast (enabled by default)
note:expecter ‘struct FMOD_SOUND 'but argument is of type ‘int’
warning:passing argument 3 of ‘FMOD_System’Playsound’ from incompatible pointer type (enabled by default)
note:expecter 'struct FMOD_CHannelGROUP
’ but argument is of type ‘struct FMOD_SOUND *’
please help me
how i can install fmod ex programmer api
Sounds like you’re trying to use FMOD Ex commands with the FMOD Studio API.
Please check the documentation at http://www.fmod.org/documentation/#content/generated/lowlevel_api.html if you are not sure about what parameters are passed to playSound.
