I have a problem with the HRTF filter.
I’m working on a game with a RTS camera, and I would like to disable the HRTF filter to avoid sound sources to be filtered while positioned in the back of my listener, as it was enabled previously :
“ [r/w] Optional. For use with FMOD_INIT_HRTF_LOWPASS. The angle range (0-360) of a 3D sound in relation to the listener, at which the HRTF function begins to have an effect. 0 = in front of the listener. 180 = from 90 degrees to the left of the listener to 90 degrees to the right. 360 = behind the listener. Default = 180.0.
HRTFMaxAngle
[r/w] Optional. For use with FMOD_INIT_HRTF_LOWPASS. The angle range (0-360) of a 3D sound in relation to the listener, at which the HRTF function has maximum effect. 0 = front of the listener. 180 = from 90 degrees to the left of the listener to 90 degrees to the right. 360 = behind the listener. Default = 360.0.
HRTFFreq
[r/w] Optional. Specify 0 to ignore. For use with FMOD_INIT_HRTF_LOWPASS. The cutoff frequency of the HRTF’s lowpass filter function when at maximum effect. (i.e. at HRTFMaxAngle). Default = 4000.0. “
Which are solutions today to modify the HRTF behavior ?
Thanks,
Dorian
EDIT : I’m using 1.10.09
