Is there a way you copy Parameter Values from 1 event to another?
(we got a problem of 4 different parameters sharing the same name)
Hi Dan,
Aside from manually copying the value of the parameter from one parameter to another, another way (especially if you have a lot of events with this parameter issue) is to use scripting. Take a look into using getCursorPosition() and setCursorPosition() functions when you find the event’s parameters to change.
https://www.fmod.com/resources/documentation-studio?page=scripting-terminal-reference.html
Thanks,
Richard
