I have a raw buffer of floating point samples read in from a .txt file. If I import raw into Audacity, it plays back just fine.
I want to push it into FMOD however and play it back.
I have tried various things but either the DLL crashes or I try other parameters and get ERR_MEMORY. data here is a pointer to my raw floating point buffer and I’m only passing in half the size in case it was a memory buffer overflow. Very confused why this won’t work.
FMOD_CREATESOUNDEXINFO creationInfo;
creationInfo.cbsize = sizeof(FMOD_CREATESOUNDEXINFO);
creationInfo.length = numSamples/2;
creationInfo.format = FMOD_SOUND_FORMAT_PCMFLOAT;
creationInfo.numchannels = 1;
creationInfo.defaultfrequency = 48000/2;
FMOD_RESULT result = fmodSystem->createSound(data, FMOD_OPENMEMORY_POINT, &creationInfo, &m_fmodSound);
if (result != FMOD_OK)
FMOD::System* fmodSystem = SoundManager::GetSingleton()->GetFMODSystem();
fmodSystem->playSound(this->m_fmodSound, NULL, false, &m_fmodChannel);
Memset the structure fixed my issues. And then I figured out the parameters needed.
memset(&creationInfo, 0, sizeof(FMOD_CREATESOUNDEXINFO));
creationInfo.length = numSamples*sizeof(float);
creationInfo.channelorder = FMOD_CHANNELORDER_ALLMONO;
creationInfo.defaultfrequency = 48000;
//creationInfo.suggestedsoundtype = FMOD_SOUND_TYPE_RAW;
FMOD_RESULT result = fmodSystem->createSound(data, FMOD_OPENRAW | FMOD_OPENMEMORY | FMOD_DEFAULT, &creationInfo, &m_fmodSound);
if (result == FMOD_OK)
this->m_isLoaded = true;
SoundManager::GetSingleton()->PlayControlledSound( this, true );
So I have the same char* buffer that holds float data. Its 38 seconds of data, but the audio plays back in 35 seconds. SampleRate is 48000. I provide 1,851,392 floats.
1851392/48000 = 38.57 seconds.
Anyone know what causes this? FMOD internal timer issue? Calling FMOD::Update too often?
^ Also solved. This was incorrect. My internal timer had some issues and the audio playback when properly timed worked just fine.
Thank you for all the info and for sharing the solution.
