Recording live vocals directly in to FMOD Studio..
Had a little poke about with the FMOD studio demo. Is there a way to directly record tracks in to FMOD studio or is it expected that you create your audio tracks using a more traditional DAW and then import the files in to FMOD studio?
I have a USB Focusrite Scarlett2i2 and a condenser mic if that helps.
Hi Rob,
The workflow is that you create the static elements of your sound in a traditional DAW, and then import them into Studio where you setup the dynamic elements.
