The Audition - Record Output was / is a useful feature in Designer, is this going to be added to Studio ?
As a DAW, Studio is specialized in dynamic audio content creation; Static audio content creation is therefore less of a priority for us. We may implement a Record Output-equivalent at some point, but it’s a much lower priority than most of the other features we’re working on. We therefore recommend that you use a DAW specialized in static audio content creation for the task.
Even if we had implemented a Record Output mode at this time, I’d still recommend that you use a DAW specialized in static audio content creation for the task; A tool designed specifically for your task will almost always be better than one designed primarily for some other use.
