RuntimeManager.LoadBank fail
in unity 2021.3.16f1
BankLoadException: [FMOD] Could not load bank ‘J:/FMODProject/Genesis/Build/Desktop/SFX.bank’ : ERR_INVALID_HANDLE : An invalid object handle was used.
int maxchannels = 128;
RuntimeManager.StudioSystem.initialize(maxchannels, FMOD.Studio.INITFLAGS.NORMAL, FMOD.INITFLAGS.NORMAL, IntPtr.Zero);
TextAsset bankAsset = ResMgr.Instance.LoadSync<TextAsset>("Assets/Res/Sound/Fmod/SFX.bytes", out var outAREx);
RuntimeManager.LoadBank(bankAsset);
What version of FMOD are you using? I will link to our documentation on the subject under Unity Integration | User Guide - Asset Bundles and Addressables.
This indicates that there might be an issue with the TextAsset you are passing into the LoadBank() function.
Could you try the following code:
Load Bank Assets
void Awake()
	var assetBundle = AssetBundle.LoadFromFile(Path.Combine(Application.streamingAssetsPath, "banks"));
	if (assetBundle == null)
		Debug.LogError("Failed to load AssetBundle!");
		return;
	foreach (var name in assetBundle.GetAllAssetNames())
		FMODUnity.RuntimeManager.LoadBank(assetBundle.LoadAsset<TextAsset>(name));
	Debug.Log("Succesfully loaded assetBundle");
	assetBundle.Unload(false);
Using that make sure the banks .bytes file is marked as so:
TextAsset bankAsset = ResMgr.Instance.LoadSync<TextAsset>(Common.RES_ROOT_PATH + "Sound/Fmod/SFX.bytes", out var outAREx);    //bankAsset.text is bank stub:SFX
I feel something wrong
Could you elaborate on the issue? Are you still getting the same error as the original post?
I still getting the same error as the original post
help
