Snapshot in labelled parameter sheet - AHDSR?
So I presume that the envelope isn’t functioning correctly as the Snapshot isn’t actually triggered when it’s placed on the parameter sheet (labelled), although it swaps between “shots” and does something to the attack. Command instrument doesn’t trigger for the same reason so that’s not an option. Is there a way of making the envelope behave as normal when the snapshot is used this way, e.g., create a level fade using release, etc.
Thanks J
If I understand you correctly, you’ve placed an AHDSR modulator on the intensity of a snapshot and are using a snapshot instrument to trigger that snapshot, and the problem you’ve run into is that the release period of that snapshot doesn’t play out when the instrument is untriggered.
If I’m right about that, the solution is to remove the AHDSR modulator from the snapshot’s intensity and add it to the intensity property of the snapshot instrument.
If that doesn’t work, have you tried the various solutions to this issue described in our troubleshooting documentation?
