Sound mod stuttering in War Thunder
I encountered an inexplicable problem with the sound.
I’ve been making a sound mod for War Thunder for about six months now, the mod turned out to be quite large and complex, a lot of sounds have been added, but mostly sounds for tanks. Shots etc.
So now I decided that it was time to add the sounds of aircraft firing, I made test ones for two machine guns and in the game when you shoot them, everything starts to lag and sometimes the game crashes.
Or it happens even if you shoot from a tank, but at the same time the bank file with the air sound is in the folder with the game, the same problems occur.
There is no such thing without a file for airplanes, everything works fine.
I tried to add the sound of airplanes from other mods, nothing has changed
What could be the reason?
There were no problems just a couple of days ago
UPD:
Now it’s stuttering for everytime
Thank you for all the information.
What version of the FMOD integration are you using? Could you please collect a profiler capture while reproducing this issue in game, then package your profiler session including banks (ticking the “Banks” option when exporting), and upload it to your FMOD Profile?
