My project has been using FMOD on Windows, GameCore, and PS4/5 platforms. Recently, I received and installed the Switch2 plugin, but I’m encountering an error during the build process stating that the platform-specific plugin cannot be found.
Error building Player: BuildFailedException: No FMOD platform found for build target Switch2. You may need to install a platform specific integration package from https://www.fmod.com/download.
Currently, the Switch2 plugin is installed and the library platform settings are configured correctly.
What could be causing this issue?
Unity version: 6000.0.50f1
FMOD version: 2.02.29
Switch2 SDK: 20.5.14
Thanks,
Thank you for bringing this to our attention.
The issue is likely due to Unity changing the Switch 2’s platform name in 6000.0.46f1 from BuildTarget.Ounce to BuildTarget.Switch2, affecting the FMOD integration’s Switch 2 platform file at /Assets/Plugins/FMOD/platforms/switch2/src/PlatformSwitch2.cs
We are currently working on a fix, which will be included in our upcoming 2.02.30 release. I will let you know once we have a build available with the new release.
I made the changes as you suggested, and I was able to build successfully.
Thank you,
Hi, just a quick update.
We’ve just released versions 2.02.30 and 2.03.09, which include a fix for this issue.
If you’re checking for the update, make sure to hit the “All” button to see the new versions listed.
