We want laser beams in our game to emit a constant hum that harmonises with the music. Currently we’re trying to do this with a global parameter called “LaserNote” with labeled values for each of the 12 note names. The laser beam event is a hum loop that responds to the parameter with pitch automation, and the music event contains command instruments on beats where the harmony changes to set the LaserNote parameter. I had to delay the command instruments slightly off from being exactly on beat though, otherwise they seem to change too early.
The problem is in the final build on mobile, the sync between the music and lasers is off, particularly in places where the music harmony changes more rapidly and command instruments are denser. I can’t reproduce the problem with live update in Unity though, so I’m wondering if there’s a more robust way to do it that doesn’t have different performance on different platforms.
I’m considering enabling Quantization on the command instruments, but with a quick test the behaviour seems counter-intuitive in live update, triggering the changes earlier instead of delaying them to occur on beat.
Because there may be multiple lasers at once and they need to be spatialised, the lasers need to be in their own events instead of being a stem in the music event.
