FMOD production method: An event contains multiple switchable parameters, which are nested events that are packaged as separate events for actual playback.
In until: The timeline module implements BGM switching. On the audio track of the timeline, two parameters of music are configured. The entire timeline has 60 seconds, and the first parameter of music has 20 seconds. The configuration position is at the 0th second of the audio track. The second parameter of the music has 10 seconds and is configured at the 30th second of the audio track, with a gap of 10 seconds. At this time, when the first piece of music finishes playing and enters the second piece of music, the parameters of the second piece of music are not triggered, which means it cannot be played.
Attempt to solve: Extend the length of the audio blank portion of the FMOD event by more than 10 seconds to resolve this issue.
Help seeking: Is this a bug, is it an issue with fmod or until? This problem greatly affects production and is not easy to detect, and the problem to be solved is very troublesome. It is impossible to individually elongate the length of each audio. I hope there is a better solution.
Thank you for your reply. I’m afraid recording videos may be a bit troublesome and take some time. I will try my best to record the videos in the future.
