Time stretch sound quality in unity
Use pitch shifter pugin and master pitch to achieve time stetch effect,like:Time stretch hack for FMOD - YouTube
I set 3 lable of speeds, 1x, 2x, 3x
When accelerating, the sound quality of the sound will deteriorate when the playback is accelerated in Unity, and the diffusion of the sound image will diverge, like a spread effect .but this is not a must every time. FMOD Time Stretch in unity - YouTube
A lot of this can be down to the sample rate of the audio file you’re using.
A higher sample rate on an audio file allows you to change pitch with fewer artefacts at the cost of requiring more resources. Ensure your raw audio file is rendered at a high sample rate and match that setting the in the asset browser’s Advance Encoding Settings before building to a bank.
It s not worked,highest sample rate is 48khz
Is that the sample rate of both the source audio file and the asset in FMOD Studio’s assets browser?
yes,the same sample rate 48khz i used,the effect its ok in Fmod editor,but not in unity editor play
Have you tried adjusting the FFT size? Higher sizes are more computationally expensive, but achieve better quality results.
FFT size is the same result,I remove the pitch shifter,keep pitch in master channel.The spread effect will no longer appear,but it will be changed the pitch
I’m glad to hear you were able to achieve the behavior you wanted.
