Transition stuck in a loop
Hi, I’ve been working through the Viking Village tutorial and am having problems with the adaptive music section. I have a transition set up to move to the chorus when the chorus parameter is set to 1 but when it transitions it gets stuck at the transition point until i set the parameter back to 0. I’m assuming that this os caused by the transition which is at the start of the chorus Transitioning back to itself and therefore not progressing through the section. I have got round this by setting the transition marker just before the section marker but this is not ideal. Is there a better way to sort this?
Hi Timothy,
Could you post a screenshot of your event? It sounds like you have a transition marker loop (parameter causes transition to verse, there is a transition on the verse that moves it back to the first transition marker, etc.).
Thanks,
Richard
Hi Timothy,
Have you had a chance to grab a screenshot of your event? We’ll be able to take a closer look at this issue then.
Thanks,
Richard
