Hi everyone,
I have issues to have my transition to marker done when the music is in a transition timeline loop.
For example, i have a music with a loop region, to make some good crossfade from end to start of the loop.
I have a Transition Region on the same loop to go to marker when i want.
My problem is, if the timeline is in the transition timeline loop, and i change my parameters to go to next marker, it will wait the end of the transition timeline loop to go to my marker.
Is it a bug ? Or i’m doing the wrong way to achieve what i want (a smooth transition within my loop and smooth transition between sections)
Here’s a video to explain
- first i play the music and switch param before the transition timeline loop : it works
- second, i play the music and switch param between the transition timeline loop : it wait’s the and of the transition timeline loop before moving to marker
Thank you !
